ABS Fuse
Old Jan 9, 2010 | 02:04 AM
Mike512512's Avatar
Default ABS Fuse
Hi, the ABS light came on in my 1994 Accord EX and I would like to pull the fuse to shut it off until I have more budget to buy used part to fix. Where is the ABS fuse and what I do I need to do to shut the ABS light off for the time being? Thanks in advance and please excuse my simple question such what I do I need to do since I don't know much about cars. Thanks!
Old Jan 9, 2010 | 02:52 AM
You should first find out what is wrong with the ABS. It could be something simple, like low on fluid, or something more complicated.
Short the service connector using a piece of wire or a thin paper clip. See: http://www.dhost.info/accordinfo/howto/cel.html
The only difference is that you will count the ABS light flashes. ABS codes are stored as a main code, a 1 second pause, then a sub-code. If there are multiple codes there will be a 5 second pause, then the next main then sub-code will flash. Post back your code(s) like 1-3, etc.
93Accord2.2
Nov 7, 2013 07:10 AM
tvandentop
Sep 17, 2011 06:42 AM
treeter
Mar 13, 2010 08:26 PM
IAAccord95
Oct 25, 2005 09:45 PM
maximyshka
Sep 30, 2005 05:25 PM
