abs light
Old Nov 6, 2008 | 09:05 PM
94accordexl's Avatar
Default abs light
hi everyone.need your help.i have a 94 accord ex with 4 wheel disc abs.my problem is the abs mil comes on as soon as i reach 70mph,no problems at any other speed just at 70 or more...bad tone rings/or pickup sensors?
thanks for any advice you may have
Old Nov 6, 2008 | 11:00 PM
deserthonda's Avatar
Default RE: abs light
you need to get the abs code ,, then post it here , then we can properly help you out
Old Nov 6, 2008 | 11:21 PM
hondadude's Avatar
On your car you can find a Blue 2 pin connector behind the glove box towards the passenger kick panel; jumper the connector, turn on the key. watch the light for the flash code.
ABS codes are two parts main system and sub system.
example 5 flashes pause 2 flashes = code 5-2, and you don't want that code anyway. LOL
Old Nov 7, 2008 | 01:16 PM
ORIGINAL: hondadude
thanks HONDADUDE,i will get that code shortly.....i like your signature,i am currently rebuilding a 22re motor out of my dads 87 truck..#3 rod bearings wear double stacked and still pulling hard
93Accord2.2
Nov 7, 2013 07:10 AM
brayner
Feb 12, 2013 06:59 PM
mickey4live
Jul 6, 2012 08:29 AM
anthonyj89
Sep 24, 2008 10:20 PM
shinobi16
May 18, 2005 08:21 AM
