abs light
Hi,
My abs light came on in my 96 accord about 3 weeks ago after getting an alignment at mieneke. I checked all sensors, they read steady at about 600 except for the LR sensor which was off the scale. Went to a junk yard, foumd a stable one, replaced it. My light is still on. I jumped the service connector and it flashed 4-2 then a long pause, 4-2 again, and then 4-8. I know this is for the front and back left sensors. I fixed the tone ring on the front left. I guess i am wondering why i am still getting a light? Why i got 4-2 twice? And how exactly, if possible to reset abs codes? And all the sensors pass the ohm test. Any help would be appreciated. |
4-2 is for the front driver's side sensor.
4-8 is for the rear passenger's side sensor. To clear the codes, remove the 15 amp abs fuse in the abs fuse box that is under the hood. |
Ok thank you. Would it matter if the car wad on or off?
You want to remove the fuse when the car is off.
Thanks guys. My front sensor was out of place and my back tone ring was caked with rust. Light is now gone.
