AC Blower Problems!?!?!?
I have a 2003 Accord 4 Dr Sedan 6Cyl. EXL AT
I have read other threads and from the beginning.... The blower had stopped working. I heard the AC click on, then turn right back off just as quickly. From reading the diagnosis sounded like the blower motor resister. I replaced the resister and sure enough the blower started working. I had cold air and it was working great. That was yesterday... Today, as I started the car up I smelled burning electrical wire, and then noticed that the blower motor would not shut down. The motor will not stop even if I turn off the AC totally. Yes, when I shut down the ignition the blower does stop. The air seems to be on high all the time and cools very well. Is my blower motor going out? I double checked and believe I have the correct resister. Any help is greatly appreciated. Thanks, Jeff |
UPDATE*
I ran a diagnostics check that I got from the DIY section. The code I get is "N". Something is wrong with the blower motor circuit. So, will replacing the blower motor fix this? Is there a How to video for replacing like there is for the Resistor? Jeff |
Did you solder in a resistor, or did you replace the whole part with a new one?
I replaced the Whole part. I have been told I may have gotten a bad part. They are swapping it out for me. So, I am about to go remove it, and take it in to swap. They said they'd have another around 2:55 CST.
Thanks for answering my post Do you have any ideas? Jeff |
That part controls the fan speed. The fan control on the HVAC or the wiring could be a problem. A volt meter should reveal if there is a problem with the wiring. You would need a shop manual and a list of the proper readings.
I replaced the part. The resistor I removed that I had purchased yesterday was burned inside. I detected a distinct burned odor. I replaced the old part with the one I just got today and everything works fine. I will continue to monitor it so I don't get stranded in 105 degree weather without ac.
Thanks, Jeff I will post with any follow ups ASAP |
LOL...today I was driving in the Texas heat and my shifter knob fell apart. I drove straight to Honda when I got finished with work and bought a new part,,,another $$18.00. FIXED.
I want my new Toyota! |
| All times are GMT -5. The time now is 10:31 AM. |
