Accessory Plug Issue on 2006 Accord
Hi! I have a 2006 Honda Accord, and for the life of me I cant find the fuse for the accessory plug in the arm rest console. Can someone please help me?
Thanks |
1 Attachment(s)
No. 9 (15A) fuse, see attached pic.
Thanks! But i checked this fuse and it's not blown. Also, this says its for the Front Accessory socket. I'm talking about the one thats inside the arm rest. The 12V one located when you lift/open the arm rest.
1 Attachment(s)
The No. 9 (15A) fuse is for both accessory sockets. Also, check the No. 32 (7.5A) fuse, that is for the accessory socket relay and audio system.
ok. Will do! I'll check it tonight. Would it happen to be a bad relay or its just the fuse that would go bad?
Thanks! |
Is the front one working?
Yes.. Front one is working, but not the one in the arm rest. Didnt get a chance to check No. 9 & 32 fuses yet.
Thanks! |
Sounds like a different animal. Based upon the manual I have, if the front socket is working so should the rear......same source. Do you have a volt meter?
Many times the problem is with the socket wiring or the socket itself if the fuses are good. |
@ poorman212, Yes I do have a volt meter. You basically shed some light on this being that you mentioned if the front socket is working so should the rear. What should I test with the volt meter? I'm assuming the actual socket.
@redbull-1, I'll double check the fuses one last time before I begin troubleshooting the socket. I'll keep you guys posted on Monday. The only time I have to work on the car is on the weekends. Thank you for your help!! All the best.. |
