accessory toggle switch mounting area for 2001 Accord
1 Attachment(s)
i have purchased a new head unit, and it comes with a safty feauture that has a wire connecting to the emergency brake so you can not view video when it is not engaged. I was wondering where would be the easiest place to mount the toggle switch i will use to fake apply the emergency brake. i was thinking right beside the emergency brake, or under the steering column. also does anyone know the best way to remove that trim piece.
thanks in advanced |
Why not just ground it out all the time?
That is how I have my Pioneer Avic-Z2 set-up. Why use a toggle switch? |
would that work if the head unit requires a specific sequence when setting the emergency brake to view the video?
No it will not.
You should do some research on-line about how to bypass your radio. For me I had to ground out 2 wires and then I updated the unit using some software I got online for free. |
Ok ill look in to that, thanks
