accord 2000 2.0L coolant drain
Old 03-21-2018, 05:55 PM
Eran Teitelbaum's Avatar
Default accord 2000 2.0L coolant drain
hello
i was trying to drain the coolant from the cylinder block but couldn't find the bolt.
it's not where the owners book shows:
the only bolt on the rear side is close to the timing gear side, but no coolant came from there, only a little bit of engine oil:
from what the book shows i'd expect the bolt to be where the red arrow points to, but there's nothing there. it's a threaded hole, but it's blocked. could it be the plug under the oil filter?
Old 03-22-2018, 03:10 PM
The Toecutter's Avatar
Originally Posted by Eran Teitelbaum
hello
That bolt isn't it. That bolt is basically a plug to access the balance shaft pin hole (to lock the balance shaft for belt replacement). I think you either need to look further up (you can just make out the coolant tube in the top of your pic), or you need to look on the front side of the engine.
Old 03-22-2018, 07:50 PM
Are you just trying to change the coolant?
Old 03-22-2018, 08:33 PM
yes i am.
Old 03-22-2018, 08:36 PM
The engine block coolant drain bolt is to the left of the oil filter.
See the illustration as part of this engine block heater install instructions.
File Type: pdf
Old 03-22-2018, 08:56 PM
Just make it simple. Drain the coolant from the radiator and refill with new coolant. This will dilute any old coolant in the system.
Old 03-22-2018, 09:10 PM
thanks for the help, i'll crawl again under the car to look for it.
i prefer to drain it completely.
Old 03-29-2018, 09:11 PM
found it!
qw
anupm12
09-15-2014 11:21 AM
slickgeek
07-20-2014 01:41 PM
hondafreak2
12-15-2006 06:43 PM
Ronin_301
07-05-2006 12:54 AM
Quick Reply: accord 2000 2.0L coolant drain
