Accord 2000 gear problem
Hello, I had a problem with my car, when i start the car for the first gear it's ok, but when it shift to the second gear I feel jerks but if i move slow then there are negligible jerks but if i accelerate a little then i feel the jerk but only for the second gear the rest gears are ok, and by the way it's an automatic honda accord 2000 LX car.
Thanks in advance. |
Transmission fluid? Use Honda fluid & only drain/fill. Honda automatic doesn't like to be power-flushed.
One minute before posting about a broken timing belt? What's the rest of the story?
You could try pulling out the 2nd clutch pressure switch out and clean it to see if it will help, Should be green in color locates below the radiator hose in the back side, close to the fire wall and on top of the differential. Loosen it with a 22mm socket, try not to loose the washer behind the switch, as it's hard to find.
Originally Posted by JimBlake
(Post 216297)
Honda had a lot of issues with trannies 98-02 ,sounds like the typical tranny issue , i would have it checked out by a shop ......any codes ???,, all motor mounts ok ?? tranny full of fluid ?? My man,, if you need a tranny and you also got possible engine issues from the other post ,, you might as well get rid of the car |
