Accord 2003 Auto Tranny question
Hi there
Does 03 accord's have any transmission oil filter if yes is it easy or hard to change it, also I was wondering if I should install a transmission cooler cause I do a lot of driving specially in the summer but I checked with some mechanics they r asking $350 to #400. I checked online that the transmission oil cooler prices are around $50 and up is it that hard to install it. THANKS IN ADVANCE FOR ANY HELP!!! Honda Accord 2003 2.4L Four Cylinder Auto Transmission 250K |
are the 6th and 7th gen accord dont have stock tranny oil cooler? just curious.
Well, where are you guys located??
Darkgreen, I know you're not in USA. The tranny cooler should be built into the bottom of the radiator. There's 2 hoses from the transmission to the radiator (near the bottom tank). I can't look up UK/Europe parts pictures, so I can only assume they're similar. Besides, 2003 is the beginning of a whole different generation of Accord so 2002 and 2003 are VERY DIFFERENT cars. Here's a 2003 USA auto-trans. Filter is up top, #4, on the ATF hose. http://www.hondaautomotiveparts.com/...da01_atm07.png Next picture is the radiator hoses. The little ones towards the bottom (#12, 13, 14) are the ATF-cooler hoses. http://www.hondaautomotiveparts.com/...da01_b0510.png |
yes Jim your correct, im from the Philippines.
Actually, I don't know what Honda does in the Philippines. It might be the same as US, or it might be the smaller UK/Europe Accord.
Just saying that Honda sells different cars under the Accord name worldwide. |
Hey JimBlake, can you tell me which hose is the return and supply for the ATF. My car is also a 7th gen 2004 accord auto, 4 cylinder
03 and newer that uses 5sp auto, it has an internal filter as any other Honda's auto, but there is an external inline spin-on filter in the detail picture JimBlake provided could be change.
Sorry, I actually don't know which is supply & return. I buy manual trans cars.
And yes, I should have said that there is also an internal filter that you can't change unless you dismantle the transmission. |
