Accord 2007 4Cyl intermittent A/C
Old May 24, 2014 | 05:34 AM
rawdeal's Avatar
Default Accord 2007 4Cyl intermittent A/C
Hi
I have an Accord 2007 4Cyl. I bought it used from someone about a month back. I am experiencing that the compressor is intermittently going ON and OFF for like 30 seconds On and 15 seconds OFF. Freon is OK.
On a side note I recently replaced the battery and sometimes( 1 out of 10) when I turn the ignition there is a clicking sound happening once but then starts normally
any suggestions?
Old May 24, 2014 | 05:38 AM
rawdeal's Avatar
Hi
any suggestions?
Old May 24, 2014 | 07:48 AM
For the AC - could be normal, could be low on 134a. You say it is ok, did you have the low and high side pressures checked?
Double check the battery cables to be sure they are clean and tight. Sometimes the cable, right where the battery end is, will get corrosion on it.
kenwood guy
Sep 15, 2013 03:02 PM
mattcadieux1
May 8, 2013 08:45 PM
danodemano
May 6, 2013 09:16 PM
danodemano
Mar 13, 2013 03:21 PM
SlyBlackDragon
Jan 6, 2012 10:13 PM
