Accord Crankcase Pulley bolt, or how I learned I can still do a pull up
Old Jan 23, 2011 | 10:39 AM
DisplacedMic's Avatar
Default Accord Crankcase Pulley bolt, or how I learned I can still do a pull up
Hi guys! I am changing (or trying to change) the timing belts on my 99 accord. I have hit a wall trying to get that crankcase pulley bolt off. It is on there SUPER tight. I read it's supposed to be on there @ around 180 ft lbs but given what most shops do to just my oil drain plug and lugnuts i'm thinking it's on there WAY tighter - especially given the car probably hadn't had it changed before I bought the car and that was almost 100k miles ago
I bought a removal tool which is basically a 50mm hex bolt that fits inside the crankcase and holds it in place so you can break the bolt w/ a 19mm socket.
Right now I've got the removal tool pinned to the ground w/ a breaker bar. I've got a leverage arm contraption consisting of an extension connected to a breaker bar connected to a 4 ft steel pipe which is all supported by a jack and a block of wood to try and focus the torque directly on the bolt itself by minimizing downward force. i am just shy of 200 lbs and i can do a pullup on that bar w/out breaking the bolt.
I am more or less at a loss @ what to do next. Anyone have any ideas?
Thanks!
Old Jan 23, 2011 | 10:43 AM
genghis1's Avatar
Some repair shops will break it loose for free with an impact wrench and just leave it tight enough for you to drive it home.
Old Jan 23, 2011 | 10:49 AM
not a bad idea... the problem is i've already taken off the ps and alternator belts, drained the radiator, the oil, removed the the sparks and taken the engine cover off. i would prefer that be the last resort ;p
Old Jan 23, 2011 | 10:50 AM
Instead of a pull up, try a jump....
EDIT: something kind of like this honda-tech.com/showthread.php?t=1908944
Old Jan 23, 2011 | 10:53 AM
I hope you're pulling CCW? I use the same arrangement you describe and have found that I can always break the bolt. I'm only 165 lbs dripping wet. W/ a 4-ft lever arm, it takes most of what I can do to break the bolt, so perhaps 600-800 ft-lbs. If you're getting that kinda torque w/o results, you have a problem.
I would suggest trying to rent or borrow an acetylene torch w/ a heating tip. Heat bolt very hot. This expands bolt length slightly and releases from end washer contact where most of resistance is located. I've tried this w/ a propane/butane torch w/o any observable improvement. Apparently you need the heat input of acetylene to heat the bolt effectively.
W/ your present desription, I'm doubtful a good 1/2" air impact will break the bolt. It will take a 3/4 or 1 inch air impact and good air supply to do this job. These can be rented at some locations.
Old Jan 23, 2011 | 10:55 AM
dunnskii's Avatar
Thumbs up Search Forums and/or Google it...
There are a 100 examples Ive seen on how to do it, Its on there SUPER tight, Ill try to find the Video I have of how to do it...
Old Jan 23, 2011 | 10:56 AM
you guys are so awesome. thanks for the quick replies - maybe i just needed a bit more confidence hearing that others have A-had similar problems and B-got it to work.
i wonder if there would be some way to brace everything and lower the car using the car's weight to break the bolt
Old Jan 23, 2011 | 10:59 AM
yeeah - there is is a pretty awesome youtube vid actually:
http://www.youtube.com/watch?v=RE-pzP8g_x4
and this one:
http://www.youtube.com/watch?v=7CridrQKj3E
Old Jan 23, 2011 | 11:01 AM
dunnskii's Avatar
YAH, U got it... Thats the Video I was looking for...Good luck man !
Old Jan 23, 2011 | 11:30 AM
Before I had a compressor I had a 2ft breaker bar with a 6ft pipe on the end and I had to put all I had into it to get it off.
Even with my impact I have to run it at the maximum PSI which is 6-700ft/lbs.
