accord issues again
ok i just replaced the fuel filter dumped all the old gas out and put gas in it it ran fine till one day i stopped at a red light and it just died. we had to push start it to get it started. i got home and tried to start it again and all it did was crank crank crank and nothing wut should i look towards being wrong.
91 accord ex 218,000 miles
2001 s2000
2001 s2000
Does the check engine light come on while driving?
Are the maintenance items up to date, like spark plugs, distributor cap, rotor, etc?
What happens when you try to start it? Does the starter turn the engine?
If you have a timing light, then you can hook it up to each spark plug wire and see if you generate enough spark to flash the timing light.
