Accord stumbles when fans kick on!
My Accord has always had this issue when the fans come on, but it seems to be getting worse. If I'm at a stoplight waiting and the fans come on the car stumbles to about 500 rpm sometimes lower. What could be the cause of this? Any help would be great. Thanks.
RE: Accord stumbles when fans kick on!
every honda I have ever been in does this and as they get older, it seems like it gets worse...mine does that identical thing and sometimes I swear its gonna stall but never has....my 88 civic did the same thing also.
I would try cleaning out the throttle body, also remove the adjuster screw and clean the port and the screw, use carb cleaner to clean everything up , then set idle at 750 rpm
