Accord window switch refrence
Can anyone give me an opinion-I need a master swith driver side 05 coupe and I am wondering if I can swap out the actual switch for the switch in four door?
Just the swith and not the trim is what I'd like to install,,,Cant find any coupe switches on the web..Thanks so much in advance |
I am not sure. You can go to a site like honda parts now (dot) com and look up the OEM part number for the 4-door and see if it is the same as the 2-door.
A junkyard is another option that may have a coupe switch. |
Controls 2-windows vs. controls for 4-windows. I bet it's physically bigger so won't even fit into the opening.
thanks for the tips
geez I didnt cross my mind but referencing the 4 dr and the 2 door swithes will tell me what I need to know
Thanks great tip!!!:D |
The only thing that MIGHT work is if you dismantle the actual switch-pack & rebuild it using parts cannibalized from a 4-door switch-pack. But first I'd keep hunting for a 2-door switch-pack.
Jimn B
Thats my idea I find lots of used four dr parts and if i remember correctly when you look at the back of a switch they look as they're made to come apart fairly easy.. as far as the switch itself being electrically compatible (i dont want to toast anything:confused:) thats another thing to look into...Thanks for the reply..
Originally Posted by JimBlake
(Post 196969)
