-   -   Advice on car getting too hot. (https://www.hondaaccordforum.com/forum/general-tech-help-7/advice-car-getting-too-hot-43020/)
jburgess Sep 26, 2011 10:32 AM
2000 Honda Accord EX. 4cyl 2.3L. My fans do NOT come on when the gauge gets up too about 75%. If I turn the AC on. Both fans come on. So it appears the fans function but they are turning on. Where should I start? thermostat replacement? Any advice is appreciate..Brand new to the forum.
TexasHonda Sep 26, 2011 12:31 PM
There is a thermoswitch B which causes fans to come on when temp reaches about 195F. Yours is likely stuck open. In earlier models, the thermoswitch B is located on thermostat housing behind and below the distributor.
You can pull connector, install a wire jumper, turn keyswitch On, and fans should begin to run immediately. If they do, a new switch should fix your problem.
In my experience overheating w/o fans will not occur unless you're in high temperatures and running at very low speeds/stopped quite a bit. If you're overheating while driving at speed, you may have partially blocked radiator core or faulty thermostat (more likely).
jburgess Sep 26, 2011 12:46 PM
Thanks for the response. It does not over heat while driving just raises considerably when I am stopped. Then i just turn the AC on and both fans turn on and cool it down. I will just need to find where the switch is and I will try the test. Thanks!!!
jburgess Sep 26, 2011 01:21 PM
I did the paper clip test. The fan kicked on immediately. Looks like I need to replace the switch. Cheap and easy repair it looks like. Thanks for the help. I ll replace the switch and see how it goes.
jburgess Sep 26, 2011 05:34 PM
Ok good news. I replaced the switch and now the fans kick on when the temp heats up. Thanks for the input. Worked like a charm!
TexasHonda Sep 26, 2011 06:21 PM
Thanks for the followup.
