AF Sensor Signal Stuck??
so i went to auto zone to get a free check up on a check engine light and it came out as a AF sensor Signal Stuch... does neone know what this problem may be? the guy said that ill prolly need to get 2 new o2 sensors.. neone else wanna add on to what he said or somtihng? THANKS!
RE: AF Sensor Signal Stuck??
Posting the trouble code will get you the most accurate help.
hmmm... ok the code that auto zone got was P2195...
anyone know what that code might be??
ORIGINAL: Dj Insanity anyone know what that code might be?? "O2 sensor signal stuck lean" generic code The computer expects to see the voltage swing on the primary sensor, and when it doesn't everswing above .5 volts the ECU has a hissy fit and throws a code. I would first check the connections to the sensor. Next is to watch the voltagereading with a scan tool or meter. |
Someone else had that same problem and it turned out to be some oil in the connection.... so like Hondadude said make sure that your connections are tight and clean on your O2 sensor (located on your exhaust manifold)
Thank you guys :D Probably will check that tomorow!!!
ORIGINAL: Dj Insanity hmmm... ok the code that auto zone got was P2195... |
