Air Bag Computer Location
Good Day all,
purchased an accidentrepaired 94 accord with a V-tec 4cyl recently.Have a couple questions for the group.
Recently purchased replacement airbags for the steering wheel and Dash, but have since been toldthis car wasbuilt in Japan, and will need a Japan madeAirbagComputer.Apparently the computer needed has a serial number"N90" at the end. The one that came with the airbags I purchased had an "A90" at the end.
1. Hasanyone else heard of this before?
2. Do you know where the old computer would be located if still in the vehicle? I looked under the heater controls and below the stereo but don't see it there?
3. Want to know how to grease or lubricate the Stereo Antenna as it is stinking at times and not going all the way down.
Thanks to all that respond in advance.
ORIGINAL: faxtell
...but have since been toldthis car wasbuilt in Japan...
1 = North America
J = Japan
I thnk the airbag computer is located all the way forward on the exhaust tunnel, forward/underneath the console, underneath the carpet.
Apply lubricant directly to the antenna. If that doesn't work, you probably have to disassemble the antenna drive assembly.
