1995 4 door leaking driver rear carpet
Hello Guys,
I really need some help with my Accord. I am getting quite a bit of water in the driver side rear floor. It's bad enough to soak up to the front driver side. I can't seem to see where it's comming in from. Any help would be much appreciated.
The leak could come from several sources. A bad seal on a window or the trunk.
I would also check that the drain tubes are not plugged up if you have a moon roof. I attached a pic of how the tubes are routed.
jza240sx
04-30-2013 04:14 PM
djrockewfewtimez986
07-06-2010 05:34 PM
