Antena help? Please...
Please someone help me find where is the anetena for the 95 accord ex 2dr since my radio is not pick up any clear single only hear the noise. There is no anetena back on the truck.
Thank you. |
RE: Antena help? Please...
The antena is a small wire that runs down inside your rear windshield... if you look at the back window towards the top you will see some small wires running down/around inside it and that's your antena, most likely it's not connected to the back of your radio... did you ever have the rear window replaced?
The rear window never been replace, the radio works before. How can I find out what the problem is.
Thank. |
first off just for the process check your fuses and make sure they're ok, next you're going to need to pull out the deck and look behind it. The antenna connection resemble a large RCA connector, it's a bit wider and longer, make sure that it's all still securely connected and that the wire going to the connection hasn't come loose, if that's okay then it's going to be your connector by the rear window or your deck itself... However, I bet it's the connection behind the radio, pull the radio www.installdr.com is a good site for instructions on that...
Hi sir_nasty, I did verything you suggested, connection on the back radio is ok, I tested with oem deck and pioneer cd player it still no radio signal. I plug and unplug the rear window connector but no help. There is a thing call anetena glass mast, if i replace that would the radio work.
