ATTN: 00AccordLX5spd!
I am in back in the Jackson Area and was wondering where is a good place to take my Accord for a Clutch Replacement? Honda Certified....I already ordered the Exedy Stage 1 Clutch. I was thinking about taking it to Carshop Inc. in Ridgeland.
Thanks Anthony |
RE: ATTN: 00AccordLX5spd!
Carshop is where I get my work done that I can't DIY. They are a good shop and not too expensive either.
Haha...they even sent me a Christmas card this year! Just call ahead and tell them when you plan on bringing it in. |
ORIGINAL: 00AccordLX5spd Carshop is where I get my work done that I can't DIY. They are a good shop and not too expensive either. Haha...they even sent me a Christmas card this year! Just call ahead and tell them when you plan on bringing it in. |
I'd probably spring for a new flywheel while they are going to be in there anyway. The master and slave cylinders I wouldn't think would need replacement unless they are leaking. Plus they are not as difficult to access.
$550 doesn't sound too bad to me considering they have to take the transmission out of the car to do the work. I don't know if they fix odometers or not. You could ask them while it is in there if they can fix it. Let me know if they do cause the speedo in my 95 is acting crazy and I fear it is on its last legs. |
I know u can replace the Master without pulling the tranny but not sure about the slave on the Honda.....CarShop Inc. said that they are going to resurface the flywheel....I dont need to 8.8 lbs flywheel or anything... I just want to be safe then sorry...That is all...
Thanks Anthony |
LOL .... called out!!!
It's cause I'm super cool[sm=pimp.gif]
hehe...
i'd recommend a new flywheel. there is a lot of heat going on around there, the thinner you make the flywheel the better chance it will warp. and if the tech cuts the disc wrong it will wobble and chatter, and guess what? out comes the tranny again. you should go ahead and replace it so you don't have to worry. |
Well, The Exedy Stage 1 Clutch Kit came in today...;D So, I called up CarShop Inc. and Schedule Monday to get this fixed. They say it will take 1 day to get it done....(Im so happy! :D) They are going to check my master/slave and flywheel to see what needs to be done..:P I will keep you guys posted.....
Thanks Anthony |
sounds like a good number for a clutch job...
| All times are GMT -5. The time now is 06:24 AM. |
