Auto Switch Window Opener Won't Work
ORIGINAL: finch13
You need to figure out if the window regulator/motor assembly is shot or the switch itself or fuses etc. New parts are probable though.
What kind of parts do I need though if its shot? Price?
does the window open at all? what year is your vehicle? If I drop the battery connection on my vehicle, there is a procedure I must go through to re-enable that auto up-down operation.
ORIGINAL: smaglik
2005.
ORIGINAL: finch13
The ones I said you need to check. We'll talk parts when you find the problem.
If you can see the lock tab thing trying to move up/down, that means one of the linkages in the door is frozen or the lock actuator is frozen. Lock actuators are about $50 new, the door panel will have to come off to take a look though.
ORIGINAL: finch13
