auto tranny probs
My tranny stays in gear a little long and shifts hard, my buddy told me that i need a new tranny filter and a flush does that sound about right? after a long while of driving its great
RE: auto tranny probs
Recently I took my 1994/1996 engine accord to the dealer for a full work up
(I had just bought the car used) they told me my trans was very old and my fluid was very dirty and that if they changed the trans fluid my trans might not work anymore. So I wieghed the odds the dealer gave me 50/50 and decided to just keep driving untill it drives no more. I guess you have to weigh three factors 1.How much money are you willing to part with. 2.How lucky do you feel. 3.Do you need to drive this car to work tommorow.Sorry I cant be of more help but mine does the same thing. On start up I only get first & fourth, but after twenty miles highway driviving at seventy five it works fine. |
Pressure flush is not a good idea on the Honda trans; instead change the fluid twice in a weeks time using Honda Z-1 ATF. [3 quarts per change]
Addressing the shift problem you should check the pressure lever cable that comes from the throttle linkage. It might need adjusted To add; many times I've seen mental midgets adjust idle speed by tightening the throttle cable, [it should have a little slack] that in turn tightens the pressure lever cable, causing shift problems FWIW There is nothing in old burnt trans fluid that 'holds' the trans together. Dirty fluid should always be changed. It's a honda trans not a 1950 GM trans. |
is there a filter or something too?
My Great thanks to hondadude,
I will follow your advice word for word.Do you think this is just a dealer trying to pad costs??? I dont want to offend any dealership mechanics, but Ive been told by a domestic car mechanic "sometimes what I put down on my recommondation has a lot added to it my boss likes to pad the bill because he gets a bigger bonus at the end of the year" I hope this is not the case there probably will be a big repair down the road that I cant handle, and when that time comes I would like to be able to trust someone. |
ORIGINAL: cxjon is there a filter or something too? |
ORIGINAL: sir_nasty ORIGINAL: cxjon is there a filter or something too? Raymond |
No change interval for that screen. Have you noticed there isn't a removalble pan on the bottom of the tranny? You have to remove & dismantle the tranny to change that screen.
LOL I hadn't looked at it yet as a matter of fact. :eek: Wowsers, yeah I guess it's not something we will ever worry about. :P
