Sponsored by:
Sponsored by:
alarm does not set
Old 01-14-2008, 10:14 AM
steve_nufc
Default alarm does not set
i have an accord 2.0 vtec executive automatic year 2000
this alarm is the standard honda fitted alarm
when i use the remote locking the doors lock but the lights do not flash i have been around all the lights which are ok no bulbs gone, i have looked at every fuse and again all are ok,i read in answer to another post the alarm resets if starting with the wiper set to intermittent that didnt work unless i was doing it wrong. and i read that checking none of the relays have stuck might do the trick which i have done and still nothing.
i am in the uk
any help would be greatly appreciated thanking you all in advance
steve
Old 01-14-2008, 12:01 PM
Default RE: alarm does not set
I don't know the answer, but since 2.0 liter was not normal in USA in 2000, I bet you're not located in USA...
Some of that stuff might be different in other parts of the world, so it would be good for us to know where you are.
Sorry I don't actually know how to help.
Old 01-14-2008, 09:07 PM
are any of the door switches or trunk illuminated on the dash when your driving?
does the car come with a hood switch? this is a common failure on usa accords - the hood switch fails and the alarm doesn't set or randomly sets of the alarm all night.
Old 01-15-2008, 05:04 AM
steve_nufc
no none of the interior lights or the trunk light is on when i am drivingi will check the hood switch but not sure where it is?
will check the manual for where it is
Old 01-15-2008, 07:52 PM
its built into the hood latch
Old 01-16-2008, 03:33 AM
steve_nufc
ok thanks i will go check it
lecompte51
07-03-2013 01:38 AM
Accord Owner
05-30-2011 09:23 PM
pk
02-06-2008 12:40 PM
FlyLow
05-12-2006 10:15 PM
Quick Reply: alarm does not set
