Best Chemicals to Clean your engine with
Well it seems to me that theres a lot of products on the market that claim to help clean your engine and restore horsepower and I was wondering out of all the products out there whats the best product that you recommend in cleaning your internals
Like stuff you add to the gas tank to clean injectors / fuel systems and other chemicals you add to the oil to clean cylinder walls and restore compression whats your favorite and outlooks |
RE: Best Chemicals to Clean your engine with
Seafoam. Seafoam. Seafoam!!!!! its the bomb. it works really well. You but 1/3 of the can in the crankcase. 1/3 in the brake booster line. And 1/3 in the gas tank
[ul][*]Cleans fuel injectors[*]Cleans carburetor jets[*]Cleans carbon[*]Stabilizes fuels[*]Upper cylinder lube[*]Removes moisture in fuel[*]De-icer Frees sticky lifters Frees sticky rings Removes moisture in oil Cleans P.C.V. systems Cleans catalytic converter odors Oxygen sensor safe [/ul] source: http://www.seafoamsales.com/motorTuneUpTechGas.htm it works very well and when you start your car, a butt load of smoke comes out. FUNNNNN!!!!! http://www.youtube.com/watch?v=yhn5_laDaIU (is was not paid for this):D |
Where do you put it in the crank case? Cuz i know the brake booster one
Put it in the oil to do the crankcase one. I usually do 1/2 in the gas and half in the oil.
But ive heard change the oil afterwards because it thins your oil out.....Finch, any input on that
when i did it, I did 1/2 BBL and 1/2 gas tank |
So put about a third in the oil fill.
put a third in the vaccum line and and the rest in the gas tank |
IMO, Seafoam is good for the BBL. MMO is better for the crankcase and I like Lucas in the gas.
| All times are GMT -5. The time now is 07:26 AM. |
