Dexron III?
Dexron III?
Hi Folks,
I recently went to Mr.Lube and had my oil changed with Mobil 1 synthetic they also drained my tranny fluid and put in Dexron III .....is this stuff ok or should I be concerned?
Also my ABS light just came on this week and remains on after about 30 seconds of driving.
Any input would be greatly appreciated.
Thanks,
Sean
Thanks,
Sean
RE: Dexron III?
ORIGINAL: 95exr
Hi Folks,
Thanks,
Sean
Hi Folks,
Thanks,
Sean
since it is on the sig , the year and model i have to assume going by your name that the car is a 95 accord...........
Although i agree with Yeu and Light ,, that it is better for the tranny to have honda flud ATF-Z1 it is also ok to have Dextrom III ,, no need to panic, it IS NOT going to do any damage,, However i would go with honda ATF-Z1 on the next fluid change ..
And lightshow my friend ( have the car towed ) ?? .... Honda says the using a non honda fluid CAN AFFECT shifting quality ) but even they say that using DEXRON III is OK..
RE: Dexron III?
you will need to jump the sc ( service connector ) located under the glove box, blue plug, 2 wires going to it,, than put the ignit key on and count the # of flashes on the dash instrument cluster,,
it might have 1 blink,, slight pause 2 blinks ,, that's code 1-2
if 1 blink, longer pause 1 blink it is just code 1 ..
but before i can tell you what is going on i need to know the abs code ..
Please input year and model on your sig so everyone who tries to help does not have to ask you .....
