Brake Light Switch.
I want to purchase a new brake light switch because I believe mine currently does not have cruise control. Just wondering what would be the better buy ACDelco - Stop Light Switch - Part #E867C for $18 or Beck/Arnley - Brake Light Switch - Part 201-1780 for $30?
Ac-Delco at lower price is way to go.
Are your brake lights working? If yes, then changing brake light switch won't help cruise control. good luck |
Why do you think you need a new brake switch?
If your brake lights are working (and I really hope they are cause anyone who drives without them working needs to be publicly flogged) then changing it will not fix your CC. |
lol...well my brake light switch is working, but I was going to change it because awhile back my gears stopped working and I had to put in a new brake light switch. Which I did and that fixed my problem with my gears, but it also stopped my cruise control from working. It was my understanding that the brake light switch also control cruise control and I figured they must have installed one w/out it...no?
The brake light switch has a pair of contacts (in my 94 Accord manual) that are inputs to the cruise unit. One is closed and one open normally, and they reverse when brake pedal pressed. It is conceivable they installed a switch not made for your car that would cause the problem you have but this seems unlikely.
If you plan to DiY, suggest purchasing a manual for your vehicle. Ebay seller automanualsource has a e-manual of original Honda manual for your vehicle for $21.99 that will provide diagnostics to determine your problem. regards |
Yeah I have the Haynes Manual already... I will look into it.
1 Attachment(s)
(Post 273680)
(Post 273721)
Yes, there are two contacts in this gen as well. IF the switch was replaced, it is possible that it is not adjusted properly.....meaning that it is NOT closing off all the way when the pedal it released, thus the cruise will not work. Especailly since it was replaced and this is when the cruise stopped working, I'm betting it needs adjustment.
You want to test continuity/resistance, one the meter there should be a setting for this. In this setting, the meter will read something like 1 (open), then touch the two leads of the meter together and the number should go to zero (or close to it).
What brand/modle meter do you have, I might be able to find a users manual online and be able to help give better directions. Or, I haven't gone off the cliff lately :) tape a penny to the "pad" the plunger makes contact with, see if the cruise works.....this could confirm if the switch needs adjustment. PLEASE only do this as a TEST! |
oh ok...i just googled it and i had it on the right settings...just like in my previous post I got some crazy number, then nothing happened it stayed at one, then when i switched them i got some negative number....i'll do it again just to verify though...
also idk if it matter, but my cruise control button will turn green, but I don't get the green light in the dash... |
