brake lights
2001 accord ex, noticed today that brake lights and also the brake light above the trunk are all out. checked the manual and it was vague about any fuses. what are the odds all 3 lights have blown? which fuse controls the system? i saw some in the box marked relays.
appreciate any help |
RE: brake lights
i have this same problem right now with 2000 accord lx .... none of the big major brake lights come on, except for that little one inside the window
RE: brake lights
chk fuses underhood # 47 20 amps
under dash fuse box fuse # 9 7.5 amps if fuses are ok, might be a bad brake switch, at the switch jump the 2 wires together white/yellow and white/black ,, if lites come on you got a bad switch |
