-   -   Brake shake (https://www.hondaaccordforum.com/forum/general-tech-help-7/brake-shake-49781/)
firefighter44 Aug 24, 2012 08:30 PM
Brake shake
just wondering if any body knows why i might still be feeling a shake in my brakes. I just replaced the front pads today and the old ones were trash, the rotor seems to be ok. it had recently started shaking when i brake and i installed the new pads and while out and about it was still shaking when applying the brakes. Any Ideas?
doctorbee Aug 24, 2012 09:21 PM
Did you use a runout tool to check for warpage
UhOh Aug 24, 2012 10:01 PM
usual culprits are warped front brake rotors. either live with it, or machine down rotors, or get new ones.
firefighter44 Aug 25, 2012 01:42 PM
Well the more i drive it now its seeming like before it was shaking in the steering wheel and now it seems like the steering wheel and the whole car as well, im not sure if its warped front rotors or bad rear brakes
PAhonda Aug 25, 2012 02:34 PM
If you pull up on the emergency brake to stop the car, do you get the shaking? The e-brake only uses the rear brakes to stop the car. Do this on an abandoned road or an empty parking lot.
Silver6gen Aug 25, 2012 06:48 PM
if it happens when you are breaking only then it is your front rotors being warped.
If it was your rear disk (which rarely warp) it would not shake the wheel. You need new rotors or get yours machined. This is a classic warped rotor case.
Honda Accords have a reputation of warping front rotors. check out http://brakeperformance.com they give lifetime warranties against warpage.
MysticBlueEX Aug 25, 2012 08:02 PM
Here is an interesting commentary on Warped Rotors. from Car and Driver Mag.
Brake rotors don't warp!! - Car and Driver Backfires
Here is another one:
-Warped- Brake Disc and Other Myths
Silver6gen Aug 25, 2012 09:58 PM
Fair enough, so the rotor doesn't "Warp" although I would think it to be foolish to say this has never happened.
I have always beded in brakes properly and still see the issue persist for my car and others. Heat is the issue, overheating the pad causes the transfer of the material to the rotor to be un-even. Well, when coming down a steep mountain pass one doesn't have a choice, they need to brake, even after downshifting.
What I have noticed is that the problem is more pronounced when the rate of heat change happens rapidly rather than in a gradual fashion.
firefighter44 Aug 25, 2012 11:01 PM
i probably need to change the rotors but im holding out because im on the verge of getting the funds together to do the rotor-over-hub conversion and save myself alot of grief in the future
my1st.honda93 Aug 26, 2012 06:50 AM
If there is an autozone near you the rotors run $50 apiece its worth the money
