-   -   break lamp lights (https://www.hondaaccordforum.com/forum/general-tech-help-7/break-lamp-lights-21754/)
paulhenrick2k8 Nov 12, 2008 07:49 AM
break lamp lights
i have this problem where i see the lights are on on the dashboard that says brake lamp.. i guess one of my bulb on brake lights are busted.. how could i change it? what bulb do i need?
thank!
falkore24 Nov 12, 2008 08:16 AM
RE: break lamp lights
You have to find the bulb if that indicator is for bulbs. It might also be for the switch that says if your ebrake is on. For the bulbs and changing procedure, take a look in the manual.
paulhenrick2k8 Nov 12, 2008 09:55 AM
it's not the ebrake.. let me check the manual if it shows how to replace bulb on brake lights. tnx!
cjdm98 Nov 12, 2008 11:40 AM
You either use a 7443,or 1157 bulb(dont remeber)
finch13 Nov 12, 2008 11:43 AM
Have someone apply the brake while you look in back to see which ones are burnt out. Then, take the bulb out and get one with the same number. If it doesn't have a number, ask the auto parts store.
paulhenrick2k8 Nov 14, 2008 05:27 PM
is it easy to remove bulbs? i dont have any exp doing stuffs on a car.
live2rice Nov 14, 2008 05:29 PM
very easy, as Finch said, have someone hit the breaks while you look to see what one it is, then this is the bulb replacement guide
Tail light
2057
Stop light
2057
Back up light
1156
paulhenrick2k8 Nov 18, 2008 02:23 AM
ok. thanks!
