Broken Speedometer
Ok, So i have replaced the VSS module, And still nothing out of my speedometer,cruise, or odometer.
So i ordered a Dash Cluster to replace the old one and see if this solves the problem. My problem is, I have no CLUE on how to take out the old dash. Ive taked the two screws out of the top of it and thats all. Can someone help me with a tutorial and/or diagram? Thanks ahead of time. Nick PS: 1994 Honda Accord LX |
RE: Broken Speedometer
go to our DIY section top part 3 from the top, ( acc 5th gen infos and manuals)
There is a shop manual for a 94 accord that you can download from www.hondahookup.com/manuals
The pdf is large, and it is interactive. You just have to click on electrical, and then gauges (23-134). There are also tests for the cruise control (23-298). Did you read an error code for a failed VSS when you replaced it? Are there any error codes stored on your ECU (follow instructions from this link http://www.dhost.info/accordinfo/howto/cel.html) You should diagnose the problem before throwing parts at it. I don't see how replacing the instrument cluster will fix the cruise control problem, but I would guess that the two problems are related. Go through the electrical test in that shop manual to DIAGNOSE the cruise control problems. |
| All times are GMT -5. The time now is 06:36 AM. |
