-   -   A/C Blowing hot at idle (https://www.hondaaccordforum.com/forum/general-tech-help-7/c-blowing-hot-idle-42114/)
mtaka Aug 13, 2011 06:39 AM
Here is the issue.
I live in Florida
When it is hot outside, the A/C blows warm when I am at idle or in Park, but it blows cold when I start driving.
I checked the both fans, and they are working. In addition, the the condenser and dryer are new because because I had a leak.
So, I did a test by putting the car in Park, and I start accelerating the car. The A/C started blowing cold, so now I am at loss.
hobieslug45 Aug 13, 2011 09:51 AM
your going to need a set of gauges to check if your compressor is weak
hobieslug45 Aug 13, 2011 09:54 AM
also was the system evacuated properly when you changed the condenser.
TexasHonda Aug 13, 2011 10:04 AM
Is the compressor engaged at idle? It may be dropping out. If it's engaged, then fault could be weak compressor, low charge, expansion valve, dirty condensor face (restricting idle air flow).
mtaka Aug 13, 2011 10:19 AM
The condenser and dryer were changed by an auto repair shop. It was changed in May 2011.
hobieslug45 Aug 14, 2011 08:34 AM
you need a set of gauges to figure out all the scenarios that texashonda wrote
