-   -   a/c blows cool not cold (https://www.hondaaccordforum.com/forum/general-tech-help-7/c-blows-cool-not-cold-28281/)
jimshady Sep 28, 2009 06:40 PM
a/c only blows 59 deg good system pressure 30 low side 220 high side.both fans work and i blocked off the heater hose.96 accord 2.2 dx with 204,000 miles.does the honda system use an orfice tube or expansion valve.
deserthonda Sep 28, 2009 11:08 PM
exp valve located in the evap case ..
hondadude Sep 29, 2009 08:26 PM
Measure vent temp with blower on low/ control set to Recirc.
Also to see the max cool temp, use a spray bottle to squirt some water on the condensor.
You might want to try some detergent and garden hose to clean out the condensor and radiator fins. NOT HIGH PRESSURE HOSE.
jimshady Sep 30, 2009 02:46 PM
59 deg is on low. the condensor looks good and i allready washed it out high side pressure is only 220 to 250 at 2000 rpm so i dont think its a condensor problem.
