A/C issues
my mom has an 02 accord 4 cylinder and her clutch fell off her a/c compressor i got the bolt from honda to get it back in i was wondering if there were any washers or anything i need and i was not able to find a diagram anyone have a link for that
The bolt you bought was #6. The shims come as a set and are #11.
I would install all of the shims. If the clutch does not spin with the compressor pulley when you turn on the a/c, I would remove a shim, then retest. http://www.hondapartsnow.com/diagram...sor-456495.png |
1 Attachment(s)
this is what i got from honda does that look rightAttachment 4566
The c-clip on the right is #3 in that picture. It holds the pulley to the compressor. If the pulley is held in place, then you don't need that clip.
The bag on the left looks like the shim set #11 that you will need to put inside the clutch plate when you install it. |
ok thank you so much
| All times are GMT -5. The time now is 06:12 AM. |
