Cabin Air Filter, How Do I Change It????
2000 Accord 4dr LX. I want to change my cabin air filter. I know it's behind the glove box but what exactly do I need todo to get it out?? Hows the glovebox come out? Thanks, Joe.
RE: Cabin Air Filter, How Do I Change It????
you have to remove glove box and support bar. once you do that, remove clips holding plastic case together. after that, remove both filters and use a shop vac to clean up the mess.
here are the exact instructions http://www.micronair.us/assets/pdfs/89.pdf |
The support bar really sucked in my car. The screws were really way too tight and even with an appropriately sized screw driver I about stripped both. I eventually took a pair of vice grips and loosened 'em up that way.
ORIGINAL: locovaca The support bar really sucked in my car. The screws were really way too tight and even with an appropriately sized screw driver I about stripped both. |
Joe,if you would have searched,, there is a write up on our DIY section with pictures and instructions
How to replace cabin air filter ..... |
| All times are GMT -5. The time now is 09:43 AM. |
