Cam position sensor
Hi everybody. I have a 1996 accord 2.2 vtec. We bought new car about 6 months ago..parked the accord. The other day I went to crank it and it just cranks and dies..code says camshaft position sensor error.. Where is cam sensor located?
Originally Posted by woody31
(Post 384085)
Originally Posted by The Toecutter
(Post 384089)
It should be in the distributor.
Any one have a idea here...I would like to get this running again...
Buy a distributor. You will not find it separately because they can not be changed.
Be sure it's not a broken belt, ignitor or icm
Originally Posted by Seanjordan20
(Post 384113)
(Post 384114)
Thanks for the reply... my scanner says it is a cam sensor intermittent signal...
However the cam sensor should be in the distributor, and there's room for 1 inside since it has a divorced coil. |
The ECM cannot tell the difference between a bad sensor and bad wiring connection somewhere between the sensor & the ECM. So the scanner says intermittent signal, that may be caused by a loose pin in some plug in the wiring harness. Electrical troubleshooting is always important to show whether the sensor itself is actually bad.
Originally Posted by JimBlake
(Post 384139)
