-   -   can someone help me (https://www.hondaaccordforum.com/forum/general-tech-help-7/can-someone-help-me-21163/)
jamrock Oct 9, 2008 04:07 PM
can someone help me
I have a 94 accord ex and i jus put an new head on it . finished every thing and it started an ran for about 0 and shut off now it wont start and there is no spark now. any suggestions ????
brayner Oct 9, 2008 04:19 PM
RE: can someone help me
unplugged crankshaft sensor??
jamrock Oct 9, 2008 06:19 PM
does an one have the wiring diagram for the distributor
PAhonda Oct 9, 2008 10:27 PM
Online manuals thread in DIY section has a link to sites with a 94 shop manual in pdf form. That will have all of the wiring information in the distributor.
jamrock Oct 10, 2008 04:01 PM
unplugged the cps nothing happened
TexasHonda Oct 10, 2008 06:40 PM
Is the Check Engine Light (CEL) on? If yes, then download codes. Diy section has procedure.
W/ no spark check the blk/yel wire at the distributor connector for voltage. No voltage would suggest an ignition switch problem. If you have voltage, either ignitor or coil is the problem. Check DIY section for procedure to determine which.
Is engine turning over? You don't say but since it started once, I assume yes.
Are you sure you re-installed timing belt correctly? If you mistimed the engine and pistons hit valves, you'll have to pull the head again.
jamrock Oct 10, 2008 08:52 PM
it started and ran for about 30. it cranks but there's no spark there is voltage and ground did the igniter test and found out that the igniter was bad, well im not sure if its the igniter or the coil so im goin to replace the distributor
