The car doesn't start
Old Jun 16, 2010 | 09:17 AM
CannonD's Avatar
Default The car doesn't start
Hello guys, I just removed my intake manifold to change the oil pressure and now i can't start the car. The starter seems fine, battery is good. My car is allitle bit low on gasoline, but i just filled in a gallon. So anyway, after i putted back the intake manifold, the car didn't start so i checked to see if there's any fuel at the fuel rail, but there was no fuel being pumped there. So i think it might be the fuel pump, but i'm not sure because it worked fine before.
Old Jun 16, 2010 | 11:48 AM
Put your year in your signature, so we know what you are working on.
Check that you connected every sensor and that all the grounds are clean and tightened.
Old Jun 16, 2010 | 12:10 PM
If you actually ran the tank dry, one gallon might not be enough to prime the pump. Put in a few more gallons.
Old Jun 16, 2010 | 02:51 PM
CannonD's Avatar
The car is 94 honda accord ex.
Old Jun 16, 2010 | 02:53 PM
CannonD's Avatar
I actually just put in another gallon, and still doesn't work. I don't know if it's the fuel pump that's causing it.
Old Jun 16, 2010 | 09:48 PM
Turn the key to ON but not immediately to START. Listen for the fuel pump running for 2 seconds then stopping.
Peacemaker98LX
Jan 15, 2011 09:05 AM
CannonD
Jun 12, 2010 10:14 PM
fishin4fun
Jul 20, 2009 07:52 AM
faosh
Mar 28, 2009 02:59 AM
patpatho
Dec 27, 2006 04:50 PM
