-   -   Car keeps overheating (https://www.hondaaccordforum.com/forum/general-tech-help-7/car-keeps-overheating-54242/)
camman Apr 13, 2013 08:34 PM
I have a 97 accord SE, it keeps boiling over. i just then drove it around my drive way (it was cooled down when i started) for about 10-20 minutes i pulled back up and steam was rolling from under the hood, temp gauge was even below normal and its not hot outside, it drove fine and it started up normally, its done this 5 times already within the last week there was never any performance changes, i even added water earlier today. the worst time it over heated was a year ago the gauge was red before i noticed and i had drove it 50 miles before it overheated. i have only seen the pass. side radiator fan work. and that one stays on when i pull the key out,
PAhonda Apr 13, 2013 09:20 PM
Coolant boiling over could be from a radiator cap that looses its seal. It could be from a leak in the cooling system. Bad thermostat. Possible head gasket problem. Clogged radiator.
When the engine is warmed up, are both radiator hoses hot? The upper one carries the hot coolant, but the lower radiator hose will be cooler, but still pretty hot. Be careful and don't burn yourself.
Some auto parts stores have a radiator pressure tester as a loaner tool. Call you local ones to find out. See if the radiator can hold about 15 psi pressure. You can also test the radiator cap as well.
camman Apr 13, 2013 09:27 PM
well the steam and liquid comes out from the overflow bottle, not radiator cap
PAhonda Apr 13, 2013 09:38 PM
The boiling coolant has to be coming from the radiator in the overflow bottle.
The radiator cap does a lot of things.
The radiator cap allows coolant to go into the overflow tank. It also allows coolant to enter the radiator when it cools.
The radiator cap also keeps the coolant under pressure, so it can be heat over the boiling point of water at atmospheric pressure.
camman Apr 13, 2013 09:44 PM
so is my engine actually over heating cause the temp gauge is normal
PAhonda Apr 13, 2013 10:41 PM
The block is not heating up according to your gauge in the car.
This is a problem you need to fix, because you will probably lose coolant and cause an overheat at some point.
camman Apr 13, 2013 10:50 PM
What do you suggest i do
PAhonda Apr 13, 2013 11:52 PM
Do what I asked in my first post.
camman Apr 14, 2013 12:17 AM
oh yeah. ill check that out tomorrow
