-   -   Car Overheating When Idle (https://www.hondaaccordforum.com/forum/general-tech-help-7/car-overheating-when-idle-5210/)
PIGGEBANK Sep 29, 2006 11:44 PM
When Idle, my heat guage goes to almost full and I have to get up to pretty good speed for the air to cool it down, then as soon as i slow down or stop it goes back up, I've made sure the radiator is full. Please help.
drummer1279 Sep 30, 2006 12:16 AM
RE: Car Overheating When Idle
there are a couple things it could be, clogged radiator, bad water pump, or your cooling fans arent engaging when the car is at idle.
PAhonda Sep 30, 2006 12:54 AM
When troubleshooting this, make sure that you don't run the engine hot for too long. Heat will eventually cause damage. You can turn on your heater full blast to help cool your engine when driving. I had to do this while stuck in a trafffic jam in 95 degree weather while in a traffic jam in Chicago. Its very uncomfortable, but will help cool your car down.
there are a couple things it could be: clogged radiator, bad water pump, or your cooling fans arent engaging when the car is at idle. Sounds to me like you have a cooling fan problem.
Are you losing radiator fluid at all?
I would start troubleshooting with the easiest then work up to the harder stuff. (Fans, temp sensor, plugged coolant system, thermostat, then water pump)
To test the fans:
Since air moving through your radiator when accelerating cools the engine, check your fans. Open the hood and see if the fans are working when you are overheating at idle.
Turn on your A/C and make sure that that both fans turn on.
If they work with the A/C on and not when overheating, then something is wrong with the fan circuit. Check for ~12 volts at the plug for the fan when overheating with a voltmeter.
Check fuse for coolant temperature switch, radiator fan relay and condenser fan relay.
If the fans are ok, then you will have to move on to the temperature sensor.
addicted2blue Sep 30, 2006 02:47 AM
i recently had this problem, raditor blew at 181k miles, then 184k miles this problem occured, problem was the thermostat, replaced it and the gasket just before i went on a trip, durin the trip i was stuck in traffic jam 2 times, 1st was for 2hrs and the 2nd was 3 hrs, not once did the hand ever try to raise over normal.
PIGGEBANK Sep 30, 2006 03:20 AM
I forgot to mention that I bought an aftermarket lightweight radiator about 10 months ago... so I'm not sure if the clogging or leaking would be a problem, may be the fans, I will wait until daylight then go out and check.
deserthonda Sep 30, 2006 04:55 AM
if you go to our DIY section there is a post about overheating.. look it up ..
PIGGEBANK Oct 1, 2006 04:47 AM
I did nothing to fix it, but the problem seems to have stopped... odd.
deserthonda Oct 1, 2006 05:08 AM
let us know if it happens again
WhyNotFab Oct 1, 2006 06:36 AM
I wish I had this kind of luck where problems fix themselves!!
drummer1279 Oct 1, 2006 08:18 PM
i had a similar issue a couple of months after getting my accord, there was a coolant leak coming from what looked like the bottom left side of the radiator, I flushed it, refilled it and put a new cap on and all of a sudden it quit and havent had a problem since.
