Car sputters on cold starts and tries to stall
Hi. My 91 accord, whenever I start it up from a cold stone start (this has nothing to do with cold as in temperature), the car will start up, but shake and sputter, and the revs will be struggling to stay up and then it dies. I have to put my foot on the gas to keep it from stalling.
But once the car get's warmer or has been idling for a while, the problem completely goes away. This problem may also have to do with an "idle from hell" problem that I have been having when I put the car in gear. Fuel pump? |
See DIY forujm post on IACV Cleaning. It can be done in place w/o removing coolant hoses w/ a bit more trouble. Avoid getting throttle body cleaner on the IACV solenoid winding.
Also clean both sides of throttle plate and bore around throttle plate w/ throttle body cleaner. If still a problem the cold air bypass valve may not be opening fully. Search for recent posts on cleaning and adjusting for correct operation. good luck |
(Post 261575)
Also clean both sides of throttle plate and bore around throttle plate w/ throttle body cleaner. If still a problem the cold air bypass valve may not be opening fully. Search for recent posts on cleaning and adjusting for correct operation. good luck Will the Haynes or Chilton manuals tell me? |
Look for FITV cleaning/adjusting.......
(Post 261609)
Compression test and block check say? Two tests, let us know what the results are of each.
(Post 261615)
I will do the compression test soon as a can but I really don't think that a bad cylinder is the sole cause of this problem. |
Look for "realfixesrealfast" on youtube. This guy is really good!
Ericthecarguy is another good youtube source. good luck |
(Post 261697)
Ericthecarguy is another good youtube source. good luck EricTheCarGuy has some good free videos but in some of them he's starting to ask for admission fee's. I figure that he really just wanted to get popular (which he is) then to make an online business out of his videos. |
Not many folks work for charity, just moderators:D
I doubt your problems are vacuum related since it idles fine when fully warmed, but those videos are much easier than my writing several paragraphs of less useful material. Shop manual is a good reference for your problem. Glad to hear you have things in hand. good luck |
