car starts but not holding charge please look
#17
No I believe you just a battery is like 90 bucks but ill replace and hopefully it goes away, it just when my car battery is drain completely when I start my car is comes straight back to 12 volts. But ill replace it and get back to you
#19
Yeah I cant drive my car Bec its draining to fast, It like my ecu not telling my alternator not to charge or something. And its not a really slow drain where I can drive it, its like I charge my battery and then 30 minutes later my car wont turn over again
#20
Something doesn't seem right in your post, so lets take a step back and make sure we didn't miss something simple.
When you start the car, you say the battery dies. Does the engine stall out? Tell us what is happening.
When you normally turn the key to start the engine, the starter turns the engine. When the engine fires up (runs on its own) you release the key.
When you try to restart the car, is the starter turning the engine, or is the engine not firing up? Do you have to recharge or jump start the battery?
