Changing AT fluid on a 98 LX ?'s
Does anyone know where the drain bolt it is?
How many quarts are needed? Do I need to drain & refill 3 times (running in between) to get most of old fluid out? This is what people recommend for Oddyssey trannies. I wonder if this applies for accords? I also heard that flushing is not advisable that drain & fill method is the best way. Thanks in advance |
RE: Changing AT fluid on a 98 LX ?'s
the drain bolt should be towards the rear of the engine on the base of the transmission If I remember correctly... Also, the only method I've done on most of my cars is just drain and fill... if you want to flush it then you could always drain it/re-fill it repeatedly or just take it to a place that can pressurize it and do it...
4 or 6 cyl??
if a 4 cyl.. drain bolt is on the pass side bottom of tranny you will need a 3/8 rachet to remove the plug.. if a v6 it is on the driver side bottom of tranny same tool. to fill it 3 qts is fine use Honda ATF-Z1 fluid,, if when you drain it fulid smells burnt or looks real balck you might want to drain and refill 2-3 times,, if it looks ok,, just do a drain and refill . I would not flush the tranny either with the flushing machine some of these tranny shops use |
| All times are GMT -5. The time now is 03:53 AM. |
