Check Engine Light
Old Apr 17, 2006 | 04:14 PM
bjingles
Default Check Engine Light
My check engine light came on yesterday and hasn't gone off. I have an appointment at my local Honda dealer tomorrow. I have a 2000 EX and would like to know what it could be? If anyone has any insight into why the light would be coming on, I'd like to know. The only thing I notice is you have to give it more gas to excelerate. What could this be?
Thanks in advance!
Jane
Old Apr 17, 2006 | 04:25 PM
sir_nasty's Avatar
Default RE: Check Engine Light
It could be a few things.... Without knowing the code then based on what you said about having to use more gas to accelerate it could be something as simple as not having the gas cap screwed on all the way (if it's loose it will give you a code) or an O2 sensor or Mass Air Flow sensor....
Old Apr 17, 2006 | 04:40 PM
deserthonda's Avatar
go to Autozone and have them read the code and post it here,,, they will do it for free,, if you go to dealer they will charge you 60-80 dollars just to read the code ..
And like Sir said it could be a # of things,, ,,if you post the code here it will give us more of an idea which system might be failing..
Old Apr 17, 2006 | 04:52 PM
lightshow's Avatar
yea there are hundreds of difference codes that can cause the light to come on. autozone will check it for free.
Old Apr 17, 2006 | 05:07 PM
bjingles
Thanks for the info, I'm going there after work, I'll post later. I just didn't want to get ripped off at the dealer.
Old Apr 17, 2006 | 07:02 PM
AgentofDarkness's Avatar
Definatly goto to autozone and get the code checked, post it here and some1 should be able to help. You should never say i have an check engine light, what is the problem b/c there are 400 problems that can cause that light to turn on.
Old Apr 17, 2006 | 08:33 PM
bjingles
Default code 1259
I went to Auto Zone and they said it was something in my fuel line. How costly are the repairs and would I be safe taking to a repair shop other than the Honda dealer?
Old Apr 18, 2006 | 01:08 AM
lightshow's Avatar
Default RE: code 1259
you have to tell us the exact code.......it starts with a p and then has 4 numbers after it.
Old Apr 18, 2006 | 01:23 AM
lightshow's Avatar
ahh you did tell us huh? p1259 vtec system malfunction......hows your oil level?
Old Apr 18, 2006 | 01:51 AM
Where did you get this P1259 number from LightShow?
That one is not in my book, but I will look it up at work tomorrow..
