check engine light
I have a 2000 Honda Accord 4 cyl. with about 98.8K miles on it. The check engine light went on recently and I took it to Autozone they said I have error code P1271, the mechanic there thinks it is variable valve timing (bank 1), he isn't 100% sure because there isn't a listing for Honda on his code checker. What do you guys say the problem is?
doesn't look like it's a valid code for that ymm
Originally Posted by misterix
(Post 282984)
He gave you the wrong code, that code is not valid. |
Originally Posted by Dr. Drivability
(Post 282989)
Pep boys
Took it to pet boys the code they gave me was P1259
(Post 283114)
here is a links to show how to inspect solenoid http://www.justanswer.com/uploads/ac...35227_vtec.pdf http://www.justanswer.com/uploads/th...ystem_test.pdf |
That is a problem with the Vtec.
Vtec runs off of oil pressure, so the first thing to do is check your oil level. Do you have a volt meter? |
