check engine light coming on
hey guys i have a 90 honda accord and i swapped a 92 JDM h22a into it.
the check engine light came on and it was misfiring so i changed the spark plugs, wires, distributer cap, and rotor. My timing is also off and i dont know if the check engine light came on because of that or because of the misfiring. What are some ways to find out and if you have any ideas please get back to me. 1990 Accord LX 92 JDM h22a exeddy stage 1 clutch |
RE: check engine light coming on
Look up how to get the CEL code and post that here .... or look up what it means
your talking about getting the codes from my e.c.u correct?
i was told to do that before im just not sure of how to do it |
Look in the DIY section. There is a bost that shows where to access the trouble codes. Find the code and post here as stated above.
another question i have is how do i adjust the timing on my h22a.. its different from the original accord motor.
someone told me that i should use a timing light and set it to 15 degrees. is that correct? |
That sounds like a question for DH or someone with a H22A.
Yeah, that sounds like a question for deserthonda, hondadude, chiovnica (all 3 are honda techs), shadow, or velocifero(both have h22s)
You may want to start a new thread entitled "How do I adjust the timing on an H22?" |
ORIGINAL: aboutblank29 another question i have is how do i adjust the timing on my h22a.. its different from the original accord motor. someone told me that i should use a timing light and set it to 15 degrees. is that correct? |
ORIGINAL: Chiovnidca ORIGINAL: aboutblank29 another question i have is how do i adjust the timing on my h22a.. its different from the original accord motor. someone told me that i should use a timing light and set it to 15 degrees. is that correct? |
your gonna need an OBD2 reader to find out the code. the plug is located behind the ashtray under the radio. after that you can just google the code and it will show you the problem.
| All times are GMT -5. The time now is 08:51 AM. |
