Clicking front brakes 91 Accord
Hey fellas!
I was driving home tonight and hen ever i press mediem hard to hard on the brakes they make a clicking sound. This is the first time it has ever done this. The rotors are warped (getting that replace withen the month) but it has never made a sound...it would just shake the wheel at high speeds. everything is stock. any help will do :) thanks :) |
Sounds like you might do a full brake job when the rotors are replaced....hard to tell over the net, a few to think about and check.
Check the hardware on the caliper, could be causing the pad to "shift" while braking. Backing plate, be sure it is not bent. Caliper slide pins, moving free? |
