-   -   Clutch replacement 93 accord (https://www.hondaaccordforum.com/forum/general-tech-help-7/clutch-replacement-93-accord-55077/)
toyhonda May 30, 2013 10:50 PM
Hi,
I need to replace the clutch in my 93 5-speed EX.
While I have the tranny and motor separated is there any additional maintenance that I should perform?
Thinking about the way we do the water pump and oil seal while replacing the timing belt; is there a similar routine at the other end?
Thanks
TexasHonda May 31, 2013 12:03 PM
Please read rules in New Member area. Don't post in the DIY forum.
Only recommendation I would make is not to touch the crankshaft seal unless it's leaking. It's easy to create a problem where none exists.
Perhaps replacing flywheel w/ new or machining old flywheel comes to mind along w/ all maintenances associated w/ clutch replacement.
If there are any problems w/ trans; worn synchronizers, loose linkages, it would be good to address these.
