compression test
i just did a compression test on my accord and i was wondering what would be good numbers.
RE: compression test
what type engine? stock? forced-induction?
it is a stock f22a1 4 cyl.2.2 liter. i was getting around 140 plus or minus 5 depending on the cylinder.
you compression is fine ........as long as there is not a 18- 20% difference within each cylinder you are ok ...
ok, thank you deserthonda
okay, i have a new question. what would be considered a low number?
Less than 100 is usually bad.
So what numbers did you get? |
on my first cylinder i had 145. on my second one i had 140. on my third cylinder i had 136. and on my last one i had 140
