Continuing my Vibration solution
has anybody ever changed the valve that controls the hydraulic mount in the rear of the engine? i have been looking into this more and more, started leaning towards the motor mounts and figured id give it a shot here first. its a 97 2.2SE. im thinking my valve has gone bad. but before i go ahead and spend $40- id inquire.
RE: Continuing my Vibration solution
i have never changed just that valve, but i have changed the whole mount before. are any of the other mounts broken?
ORIGINAL: lightshow i have never changed just that valve, but i have changed the whole mount before. are any of the other mounts broken? |
So the mount holds vacuum, and the control valve is also working. i did all the honda troubleshooting as per the service bulletin. they say to replace the mount. its pretty pricey so i will see how bad this vibration gets then ill go after it. for now i will just deal with it. ::end Rant:: lol
Did you look online for the part or call a honda dealership? Just our of curiousity how much did they say the mount cost?
are the other motor mounts ok ??
ORIGINAL: Markus26 ORIGINAL: lightshow i have never changed just that valve, but i have changed the whole mount before. are any of the other mounts broken? |
the mount is roughly $300- and that valve is about $50- ill probably change both just to be safe.
The honda bulletin i got from a friend that works for Honda. |
