-   -   coolant problem (https://www.hondaaccordforum.com/forum/general-tech-help-7/coolant-problem-7691/)
lm_dicp Feb 19, 2007 12:26 AM
coolant problem
My car is accord LX 98.
Today, I found the coolant tank was empty, and I filled it. But after I drived 20 minutes I found it was empty again, so I refilled it . Then I drive for another 30 minutes, It happened again. I dont konw what's the problem. Is there any possible leakage or just because radiator need more coolant. Hopefully, someone can help me. thanks!
Ericsmiller88 Feb 19, 2007 12:54 AM
RE: coolant problem
Have you checked your oil, does it look like chocolate milkshake? [/align]Could be a bad head gasket.[/align]Also check the hoses could be coming out when it is under pressure. [/align]I would say clean the engine compartment so that all of the old coolant is gone, this way if there is a leak it is easier to spot.[/align]or you could always have a friend drive behind you to try and spot leaks?[:-][/align]
lm_dicp Feb 19, 2007 01:02 AM
RE: coolant problem
Thank your for your suggestion.
If I go to garage to take a look, how much I will be charged? (just check if it is leak)
Thanks
Ericsmiller88 Feb 19, 2007 01:09 AM
RE: coolant problem
psssh idk about that could be any price depending on the place you go
i have about 3-4 shops around here and each charge diff. some cheaper then others
i always hop from shop to shop though and take the cheapest guy :D
deserthonda Feb 19, 2007 01:10 AM
RE: coolant problem
just have a shop or yourself pressure test the cooling system, if any leak it will show up
the charge to just pressure test system and let you know what is going on cannot be more than 30-50- dollars .. if they find a leak then ask them to give you a quote and let you know exactly what is leaking
let us know ..
lm_dicp Feb 19, 2007 01:38 AM
RE: coolant problem
Can I fill radiator and tank to look for leakage spot? Does this damage my car?
Thanks a lot.
lm_dicp Feb 19, 2007 02:17 AM
RE: coolant problem
I just check engineer oil, it looks like chocolate color. what is the problem?
Crazyguy Feb 19, 2007 03:40 AM
RE: coolant problem
if its like milk chocolate then its time for a headgasket.
deserthonda Feb 19, 2007 11:03 AM
RE: coolant problem
go to a shop and have them chk out if the head gasket is blown,,,,,,,did engine overheat on you recently ??
